Lock Module - Plastic Clip
Hi
After fixing the windows regulator and trying to put the door back together I have broken the plastic clip which the locking stud which goes up and down when you lock and unlock the door connects to, which the connects to the door module.
Anyone have one or point me in the right direction as to where i might find one?
Jon
your local skoda or vw dealer, i think the polo has the same set up as the fabia but please don't hold me to this
Does anyone know the part number of this or even the correct name?
Jon
Removing and installing the locking button
for locking rod
The locking knobs must be removed and installed as described
below.
Failing to comply with these instructions may cause the
locking rods to loosen or the support may become damaged.
Removing
– Turn the locking button 180° to the left.
– Remove the locking button from the top.
Installing
– Insert the locking button with the marking (dot on top
side) on the locking rod into the vehicle.
– Press the locking button down onto the locking rod until
the spline is at the level of the door trim panel.
– Subsequently, turn the locking button 180° to the left.
The locking button may project about 0 to 2 mm above
door trim panel in the locked position.
