RNS 310 in Octy
I just got a secondhand RNS 310, it came out of a VW and I'm hoping its going to work/fit in my Octy II. Anyone know if its compatable? also I dont have a disk or code so where can I get these please?
Any help appreciated.
Should work but illumination will be wrong colour. Depending on age of your car you might have battery drain issues (new CAN gateway needed)
Code will be from a dealer, Discs from anywhere, Download one, Ebay etc etc
Thanks, I dont suppose you can change the illumination colour then? The car is a 55 Plate L&K, would I need a new CAN gateway (whatever that is?).
No you cant change the colour, You might need a new gateway (£100 ish), only way to know for sure is to fit the radio and see if your battery keeps gooing flat, if it does then the gateway needs replacing.
