R32 Brakes vs 17" Alloys
As most of you know i had an R32 Brake kit fitted recently which also incorporated me using 10mm spacers to guarantee fitment.
Well today out of curiosity i decided to try and fit them without the spacers.
The answer is……… Yeeeeeehahhhhhhh they will fit under 17" Zenith Alloys (7.0J ET54 x 17") WITHOUT spacers.
Now this is using OEM Disks aswell. On looking at the disc the hub is a bit wider than the standard ones hence this is probably why it fits. There is about 3mm of clearance. If you use other discs i cant comment.
I just went and took them out for a spin and all is perfect.
So if you have been holding off buying them then fear not. Using OEM DIscs, Calipers & Pads they will fit under 17" alloys :thumbup:
I'm really pleased for you Carl, :giggle: now, about them 10mm spacers????
F O :p
(and that doesn't mean Foreign Office as that is FCO :giggle: )
F O :p
Is that a no then :o
We will see. Leave it with me for now as i don't know if im going to put them back on or not :thumbup:
Good news. They must fill the whole of the 17" Zenith.
Edited by a_waugh
No worries mate, I was more interested in trying before I buy tbh.
Edited by Pagey1255
Yup they do.
I might take a pic after the F1 if i remember :thumbup:
You can try if you wish. Just need to clean them up as they have Silver Hammerite on from when i painted the Hubs :thumbup:
Edited by vRSCarl
3mm is cutting it fine, though I have run less clearance on my 16" winter wheels. Bremsport work on a minimum of 5mm
