vRS engine surging
Hi chaps n gals comin home this morning and started to notice that when the turbo kicks in its surgin hard to describe its like the turbo wants to unleash but wont big lumps of power but backs off 1st n 2nd gear ok but 3 4 5 it does it car feels lifeless too not as quick as it should be no faults on vag com scanned it as soon as i got home n nothing, any ideas peeps
N75 solenoid valve (fitted on the intake pipe)
Steve
N75 valve part number: 058-906-283-F
Steve
Steve
already replaced it about month ago, brand new from vw with other problem i had lol ,
Had your fuel filter changed recently?
Does the car have a remap?
ive just had the exact same problem with mine.felt like limp mode at first,then misfiring really bad.hooked it to vag com and there was no fault detected,but it was misfiring on all four cylinders.one maf meter later car is running sweet.when they go they dont always log a fault for some reason.it could be that mate,£93 exchange.
still got the same maf on form day 1 lol 140k pmsl might just order one n b done with it wont hurt
hi chap the car was not long serviced about 2 months ago not sure if they did the filter thou to b honest and yes it has remap it didnt do it coming into work tonight stumpped
yeah it still could be your maf though. mine wasnt doing it all the time either, in fact the day i left it at the garage he phoned me up and told me he had taken the car out and gave it a good run and it was running perfect with no faults detected! when i picked it up later i didnt get to the end of the street and it was misfiring really bad. let us know how you get on with it though. by the way, mine has done 101,000 and i think it was the original maf so you havnt done too bad out of yours!
cheers chap will order one on friday where did u order yours from ???????
17705 fault possibly??
no error code came up bud all clear apart from door mech on the blink
the garage it was in ordered it from TPS ( trade parts specialists ) they just do genuine vag parts. £ 93 they keep your old one and make a new one with it. in fact, i got told that my local skoda dealer gets their parts from them but not too sure about that. the bloke who sorted mine had a misfire counter on his programme. thats how he knew it was misfiring on all four cylinders so ruling out coil packs and plugs. it was still a bit of a guess but an educated one! how old are your coil packs? the early ones were awful. the newer ones end with an R. they have a date of manufacture on them as well so it could be one of them.
i replaced them allabout 2 years ago because one packed up so replaced them all with new plugs , will have to see when i change the maf lol typical got intercooler comin tomoz too r well more flippin money ha
They won't have changed the fuel filter, unless you asked for it, as it's not on the service schedule.
You may aswell though if you're trying to rule stuff out. They only cost about £6.50, and takes 10mins to change. The filter is held on with a giant hose clip, and the fuel lines are on push connectors.
Did you replace the N75 with the correct one for your car, or one of the old slow response ones that people use to get a boost spike!
No harm in trying a new MAF I guess. Let us know how you get on with it buddy
ordered new fuel filter , ordering maf tomoz as for the n75 it was a brand spanker from vw ?????????????F might try my old one back on tomoz running out of options other than a match n petrol to it pmsl
Hi all again new maf on and no change still the same got fuel filter will put that on tomoz can anyone tell me how the two pipes come of it had a quick look but thought i would ask u chaps first before i break sumit pmsl
You just have to squeeze the sides of the pipes to get them to release.
Make sure you have a spare hoseclip in case the one around the old filter needs to be replaced.
Leave the car standing for a few hours or pull the fuel pump fuse out and run the engine until it stops to de-pressurize the fuel system first otherwise you'll end up with fuel spraying everywhere.
Google it or search on here to see how the pipes work. It's well documented.
Don't force them, as they will break and you'll have to replace the whole fuel line......
cheers bud
