Heater fan
Hi, any ideas why my Dad's heater fan has stopped working on settings 1, 2 and 3? It works fine on number 4.
thanks.
thanks.
It sounds to me as though the heater rheostat has givven up the ghost, basicaly it will be working on no 4 speed because its getting a straight/full 12volts to the motor, the way it works is to get no 1 or 2 or 3 speeds working it steps the voltage down by using a resister, this is found at the back of the passengers glove box just remove the glove box and you will see a plug like connector going into the heater box with large wires and its only a matter of removing it and replacing it with a new one. just make suer when you have fitted a new one that the heater fan works and isnt seizing as a seizing fan motor will blow the new resister
Thanks :D
