idle speed increase?
hi folks, can any of you vag-com boffins tell me how to adjust the idle speed on my felicia please, it has a 16v polo engine with magneti-marelli 1av ecu, i've tried going into adaption, channel 01 but that does not work
thanks
thanks
You might want to indicate what software you are using, how you cycled the ECU...so many variables that would cause this
thanks
IIRC off into the engine controller then measuring block 6, or is that what you mean by going into channel 01?
sorry i forgot to report back, it was becuase my ignition timing was miles out, the v60 was on it's highest setting to compensate for the over-advanced ignition and rough idle
