interesting performance car reading for the geeks amongst you
found this internet site interesting.  http://www.rri.se/index.php?DN=29
656 different vehicles, 1 dyno (hub dyno so accurate),
and comparison graphs of manufacturer stated output Vs actual output.  Quite alot of surprising on the outputs and confirming what people thought about the likes of the focus RS etc
all the below are with reference to the manufacturer claims
Golf edition 30 8 Hp under
Golf GTI 5Hp under
mk6 golf GTI TSI 5hp up
Golf R32 23Hp under
Leon cupra 11hp under
Octavia vRS 2Hp under
Scirroco R  2Hp up
scirroco TSI 8Hp under
Audi S3 2Hp under
Audi TT 3.2 S tronic 30Hp under
so the TFSi engines seem to be pretty much on the money.  the V6 not so much.
the diesels
Golf 2.0TDI CR170 6Hp down
golf 2.0TDI PD170 3Hp up
fabia vRS, 1Hp up
now for the other hot hatches
Focus RS is 20hp under
Civic type R is 16hp
Meganne RS250 18hp
Focus ST is 9hp under
08 impreza STI 30Hp under
Astra VXR  11Hp under
Vectra VXR 38Hp under
Mazda 3 MPS is bang on the money,
Mazda 6 MPS is 7Hp above
Nissan 350Z is 34Hp under
always amuses me when people think their cars are running at alot more than the manufacturer claims. evidently it seems much more likely to be running less
can you tell im bored :grin:
found this as well-
Top gear test track times
http://www.bbc.co.uk/topgear/show/powerlaps.shtml
Edited by vRSy
A hub dyno will be more consistant than a tyre one sure, but it still won't be entirely consistant unless all tested cars have the same overall gear ratio from crank down to driveshafts.
Also, with that number of tests, the atmosphere in the dyno cell (temp, pressure and relative humidity) will have had an effect, and differences in the installation (such as SMIC vs FMIC vs top-mounted inter-heater on a turbo engine) will have effects.
not much of a shock, they could do with doing a test for MPG as well :thumbup:
FWIW if they are doing the tests back to back, then at some point the amount of oxygen available to the car will be lower.
There are a lot of factors, so I'm sure none of the RR's are actually that accurate.
dont forget the dynos measure the ambient pressure, temperature, air content etc and these are taken into consideration in the calculations.
Absolutely - there's still the fiddle factor to get back to the fly-wheel figure. Interestingly, in the list, it's mostly the 4wd cars which are significantly down on quoted figures!
Chris
