Brake advice
Hi,
I need to replace my front discs and pads.
The car is a 2001 Fabia Combi 1.9 SDI with 256mm diameter discs and FS III stamped onto the calliper.
Could you tell me whether these discs and pads are the correct type/ size:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110566083001&ssPageName=STRK:MEWAX:IT#ht_1213wt_1137
I'm struggling to find a company that can tell me for sure which ones I require as apparently, even with my number plate, there are still several options :S
Many thanks,
Jim
EDIT: I know the brakes are listed for an A2 but the only box I could find with what I think is correct.
Edited by jimbell
Can't really tell you anything from there.
just order off eurocarparts or GSF or go to your local shop. job done :)
tbh you should try the skoda dealer, in a lot of cases the genuine parts are roughly the same price as pattern parts
Last time I bought brakes I got them here.
I've used this company a few times and find them
reasonably priced and I found Graham the gaffer to be very
helpful :thumbup:
http://www.jorily.com/catalog/
I agree. Tbh I nearly always go to my dealer for parts even bulbs. They charge about 50p for a brake light bulb, local small parts shop £1.50.
