REMOVING PLUG FOR RAD FAN CONTROL SENSOR
Right i thought i would have ago this mornig at changing my rad fan control sensor. I can't get the bloody plug off though that plugs into the sensor! I have tryed pulling it off twisting it off it won't budge i deon't want to break it, anyone got any advice on whats the easyest way to get the plug off or am i just being abit of a dummy not being able to get it off? any advice would be great.
Paul
There is a tab on the side. You need to rock the tab backwards and push the plug in against the rubber seal inside, that will release the tab and then you can pull it off.
Thanks alot mate, ill give that a try,
