front foglight bulb changing
easy when you know how , so the issue is how on earth is a foglight bulb changed do you partialy remove the panel under the engine that screws into the front bumper i messed on for ages replacing the headlamp bulbs but once i knew how ( now i can change them both in less than 2 minutes ) so a bit of guidence on changing the bulbs would be most gratefull many thanks....... will
The front bumper grill has 3 parts. The 2 small ones on each end are your access to the fog and drl bulb.
Push hard towards you, só it will come out.
Stick hand ( if small) inside hole and where their is a silver plate. Push away from you and the whole fog light comes out.
Putting back in the fog light, make sure that the silver plate has locked ( try to pull out the light)
The grill start putting in from the top first and push in.
Hope I have helped.
Edited by alberg
Hope I have helped.
thanks alberg managed it straight away ...easy when you know how .thanks again
