VCDS results
got my car VCDS'd and came back with these results?
means not a lot to me
2 Faults Found:
18026 - Glow Plug Relay (J52): Short to Plus
P1618 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
Readiness: 0 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ASR.lbl
Part No SW: 6Q0 907 379 AG HW: 6Q0 907 379 AG
Component: MABS 8.0 front H03 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002229
Shop #: WSC 13765 000 00000
VCID: 8200DB6FA467
No fault code found.
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F2E08BAF94C7
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 26042
Shop #: WSC 13765
VCID: 3C7CE5970603
3 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 11 AIRBAG VW51 0008
Coding: 12593
Shop #: WSC 13765
VCID: 1E380F1FB0DF
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y0 920 972 S
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 28401
Shop #: WSC 13765
VCID: 4FA6A25BA7B5
TMBWU46Y964431425 SKZ7Z0E2998145
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 003D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
VCID: F0E481A79ACB
2 Faults Found:
35-00 - -
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
VCID: 6FE602DB07F5
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 60 Komfortgerát 0002
Coding: 00067
Shop #: WSC 20021
VCID: 3D7AE8931D19
Part No: Steuerger
Component: t Fahr. antwortet nicht
Part No: Steuerger
Component: t Beif. antwortet nicht
Address 55: Xenon Range Labels: None
Part No: 6N0 907 503
Component: Leuchtweiteregelung 0005
Coding: 00010
Shop #: WSC 13765
VCID: ECDC95D7B6E3
Address 56: Radio Labels: 1U0-035-156.lbl
Part No: 6Y0 035 156 EX
Component: Radio YD5 0015
Coding: 00400
Shop #: WSC 00000
VCID: 9024E127FA0B
End ---------------------------------------------------------------------
Then afterwards the scans were cleared and only the steering angle sensor repeated itself?
steering is fine however :wonder:
Steering angle sensor is used for ESP and other things too.
Did both of these come up?
2 Faults Found:
35-00 - -
If they did and not just 00778, then I'd be considering finding out what the correct coding for your car is and having it fixed.
I'd drive it a bit, scan it again after a couple of days then see what comes up and look at how to fix them.
Edited by cheezemonkhai
2 Faults Found:
35-00 - -
I actually cant remember? :doh:
I dont have ESP?
only have ASR but i do not use it... i turn it off everytime i drive
Car is heavily modified?
never had any problems with steering... it drives bob on :thumbup:
Edited by BigJase88
Try clearing them and seeing if any pop back right away. I bet most are just intermittent things, probably caused by the voltage blip that brought up the voltage too low fault code. :) Your MAF might be on the way out though.
And just had a thought i also got the egr disabled when i mapped it if that makes a difference?
p.s i have no idea
yeah i got them cleared and the only one that re-occured was the steering angle sensor
the battery used to be low
glowplugs were knackered
MAF was unplugged and turned over
the Control module i believe is aircon (i drilled the aircon condenser by mistake :giggle: )
Edited by BigJase88
If the rest don't come back they are not of concern.
Can you find out if you get just the steering or if you get it and the coding errors
If you have the coding then somebody could have coded your car to expect functionality that is not there, hence the error code.
IIRC you only have the steering angle sensor if you have ESP, so if your controller is coded to say you have it but you don't then that would cause the fault to pop up.
http://www.ross-tech.com/vag-com/cars/steeringangle.html
Can you please go and see if you have an ASR or ESP button.
i dont have ESP i only have ASR
I have recently had the front console bushes done and the steering wheel sits say 20 degree's off centre....
i believe both codes popped up after the rest were cleared.
maybe i just need the car aligned?
Edited by BigJase88
No ESP means you shouldn't have that sensor (I think) so it is essential that you go and check if you have the coding error still.
If you have that error then your car has been coded as if it has ESP and that could explain the other problem.
I would also get the alignment done at the front, but that's more from a tyre wear and car control etc point of view.
yes both codes came up.... the sensor and the coding
Can you read the coding for the Controller and put it up here please.
To me it sounds like the controller is incorrectly coded and expecting a device that may not be there.
After all the error is no communications rather than intermittent or implausible.
Finding out what the coding should be might be a bit of a mission, so you might need to go to a dealer.
If you know anyone else with the same spec car as yours and the same controller part number then you could see what they have stored.
i actually got the car scanned at a briskoda meet...
i dont have vcds at all...
car drives fine and has no warning lights or problems so im not too bothered by it.
if its not broken don't fix it and all that :)
thanks for your help :thumbup:
Oh and the ASR works too :thumbup:
Edited by BigJase88
I'm not a mechanic so can't tell you what's what exactly, but if you think it could be a safety related issue, then obviously get it checked out.
