Does passat roof rack fit on superb 1 model 2006-2007?
Hey guys,
I found a roof rack on ebay for a passat, does it fit on my superb MK1 2006-2007?
Is the width of a superb same as passat?
Thanks!
I would have thought so...maybe it might be of help if you went and checked the dimensions of the passat and compared it to the superb...and i also think there is enough adjustment on the roof rack to make sure...also it might pay to go on halfords web site and check the thule foot kit...if the same part number is for the superb then it will. On my superb there are two marks on the underside of the upper doors and that is where you place the clamps, and there seems to be quite a bit of leeway when it comes to the final adjustment before one tightens up the clamps.....hope this is of help
I'm 99% sure it will fit. They're the same width.
The Passat and the Superb use the same windscreen, so the width must be the same. The Superb is, of course longer in the roof.
rotodiesel.
rotodiesel.
I bought some mont blanc roof bar for my Superb and the fitting instructions where the same as the Passat, so I would say a yes
I looked at the Thule website and I found that the superb has an other set than his little brother the passat.
Thats why I'm think there is some difference between them.
My friend has a passat break, but he doesn't have it because its a break.
Does there someone who ever tried this?
Regards,
Michael
And what about the origineel roof rack Vortex for a passat from 1997.
It is only 5 times used and i can buy it for 50€!
Would it fit?
regards
VW passat roof rack or skoda superb roof rack..............
Theres only one way to find out...................
FIGHT!!!!!!!!
Yes they will fit.
I had on my Superb (2005) Thule roof racks and they are same as Passat 3BG has.
