Scan Volvo V40?
Just wondered if I could use my HEX+CAN cable with my sisters Volvo V40 1.8? Would it work if I found some software to communicate with a volvo ECU?
Yep, will/should be able to read basic error codes.
IIRC, there's a section within VCDS for the basic error code readings. Try the 'OBD-II' button on the bottom-left when you open VCDS.
Steve
Depends what year and engine the Volvo has.
