ABS warning light
Hi all,
Abs warning light came on briefly today has anyone else experianced this??
Did a search but to no avail....
Thanks in advance :)
was it under braking?
Sorry didn't write full explination...cookin dinner.
I was approaching a corner and was going slow & not sure if If the light came on under breaking or while crawling in second, It only came on for a second or so & beeped at me twice, at first thought it was hand brake but was that ear piercing no fuel beep.
Have driven the car around since & "tested" the breaks & no lights or beeps..
Do ya rekon I should take it in?
maybe just low fluid level!
level's under the battery on a vrs so its a battery out job top left of engine bay beside egr valve
Edited by BigJase88
pretty easy though
Where's the thanks button when you need it!
Is it an easy job? no torx bits or anything?
Will have a go at it tomorrow, what a silly place to put a fluid bottle....
Any chance this is just an electical glitch/gremlin?
edit that im talking balony....
power steering is below the battery.....
brake fluid is top left of engine bay beside egr valve ;)
you may need a small funnel to top it up
Edited by BigJase88
Checked the brake fluid & all seems fine, if a little dirty!
Am still wondering if this is a fluke or may be something worse :(
Last service wasn't that long ago & had both rear disks & pad replaced!
Got a 70 mile journey tomorrow so we shall see...
Edited by pieman[vrs]
Maybe just braking and going over a bump locked the brakes! Mine does this now and again with my brembos
Was going over a speed bump at the time so that might explain it!
Damm those spped bumps! :moon:
Thanks for the help!
Will post back if it happens again.
:D
' date='09 September 2010 - 19:20' timestamp='1284056420' post='2100527']
:D
Mine also did that when I went over a bump, but mine turned out to me having damaged the abs sensor :( the light came on and off for a few days then went solidly on.
Hope you don't have the same problem as me!
Rio
Rio
I hope I don't but If I have the same problem what kinda dammage (£££) am I looking at?
' date='09 September 2010 - 19:57' timestamp='1284058652' post='2100586']
Cost me around £180 at a Skoda dealer, but you can have it done alot cheaper if you can find a decent independent garage.
Thanks mate :)
Things worse now :(
