Picked up my new wheels
Well my old S3 avus ones are jiggered!
1 had a crack in it in the inside lip.....
que the new wheels
Porsche Twists
7" 17's up front and 8.5" 17's out back
Adaptors are en route from Germany as we speak, hopefully have them on by next week.... :D excited
You work out offsets and which adaptors you needed then? :)
Look forward to seeing them.
Steve
35mm on the front and 25mm on the rear i got the info from bennett who used to run porsche twists with brembo's :)
Looking forward to seeing the pics of the new wheels.
:yes:
Oh this should be interesting, look forward to seeing them! B)
Andrew
just make sure you put them on the right way round, so it doesn't look like you're going backwards
will you need these adapters for any wheels m8 or just these?
i havent heard anything from demon tweeks yet
Theyre adaptors and spacers all built into one
They convert the skoda fitment (5x100) to porsche fitment (5x130) so you can bolt on porsche wheels
Im using 35mm adaptors on the front which should clear the brembo's
I might stick the back ones on tonight! Dont have the front adapters yet :)
How about some photos??? :p
as above.... havent you dont that little job yet emoticon-0110-tongueout.gif .......emoticon-0102-bigsmile.gif
would like to know if anyone can 'lend/fit' you a set of 17" wheels on the front to try m8
here's some taster pics
Wheel Porn!
Nice
:yes: :yes:
Very nice. Cant wait to see these one :thumbup:
What size tyres you running on those..can you use the standard wheel bolts ?
running 205/40/17's on both the 7" fronts.... and the 8.5" rears with a bit of stretch
adapters come with bolts required to bolt to hub, then you just use your oem fabia bolts to bolt the wheels to the adapters
job done
Lovely! And should get a nice bit of stretch on the rears, I'm running 8x17'' Evolos with 205/40/17 and there's a tasty hint of stretch on them B)
just use the rear adaptors on one side of the car, will give us an idea on how it looks. B)
