Skoda Fabia Door Card removal
Hello,
I'm trying to get to the speakers in the front door panels of my year 2000 Skoda Fabia.
The Haynes guide says to remove the window winder, but I can't work out how to do it without breaking it.
I've looked at the thread made by Xavier, but this seems to be for a more modern (or better) fabia with electric windows! and the photo links seem to be dead.
Any suggestions?
Thanks,
Tom
You have to release a clip on the winders. Normally you pinch either side and then slide away from the arm or something similar. If you search for help on the door carrier repair then this will include how to do it, as it's normally the rears that leak!
For more help it might be worth posting in the Fabia section as well/instead of here.
HTH.
Watch this and all will be clear :thumbup:
Thank you so much!
After watching that video I got it off straight away.
Can't believe how simple it turned out to be, I spent about an hour trying to get it off.
Thank you so much!
Glad to help :thumbup:
Just did mine so had info to hand :yes:
this is going to help loads!
  2. Tap Permissions โ†’ Notifications.
