vag codes: 18009 & 17056 (eobd p1601 & p0672)
http://i631.photobucket.com/albums/uu40/mcd_racer/diagnostics/User008_01005004952.jpg
Good morning all,not sure if this will work, screen shot from my scanner (snap on), ok,i need to do a physical check on glow plug number 2,supply voltage and bench glow test,also when my glow plug tester lands, a test in situ, with out having to disconnect any supply rails etc, that will be an interesting test.
18009 mentions terminal 30,i know this is a standard recognised relay pin, any views my friends, i cant see how the relay could give a single problem to a single glow plug.
1 last question: any one know the location of the glow glug relay so i can check supply's,earth and continuity checks ???
Cheers for your time folks, andy
Edited by andybaz
You may find this article on the VW tdi club forum interesting for diagnosing glow plugs issues, has some good piccies too.
http://forums.tdiclub.com/showthread.php?t=79819
Hope you get to the bottom of it soon.
Hi folks,update so far, used my new glow plug test tool, neat bit of kit, although i wouldnt pay the £90 +vat for one.
All 4 plugs are good,forgot to take me multi meter, next stage is to check the feed supply bar across the topof the plugs to make sure there is actually voltage at all 4 and not just the suspected no2.
Will let you know what the outcome is.
