CR170 oil filter removal
What do you need to get the oil filter out of a CR170? Is it a 32mm like the PD140 is?
Edited by Keith Lard
you also need to loosen the throttle valve and remove engine cover bracket or you can't get it out
Yeah that should be no problem, just wondered if the cap is a 32mm fixing though? Havent got the car at the moment so cant pop out and see what is under the bonnet!
Sorted today. 32mm socket does the trick, oil&filter changed in ten minutes once you get the right tools!
If you split the filter and the cap they come out individually.
