Music to SD card
Can any one tell me how to down load my Itunes onto a SD card so i can play it in my Bolero.
Make sure they are MP3 format (itunes can convert if required) then just copy them onto the card.
You can even drag n drop the folders if you want
Thanks Lads....
Is it easy to change them to mp3 format if they are not?
Thanks Lads....
Depends on what format they are. If it's something recognised by iTunes, then it's simple. You just make sure iTunes is set up to convert tracks imported from CDs to mp3s (under "import settings" in the "preferences" menu) and then you can select whichever tracks are not mp3s and from the "advanced" dropdown menu at the top select "create mp3 version" and it'll do it. Job done.
If you have a full "Nero" CD burner package, there is an good converter included; if not, there are plenty of free ones out there; just do a search using the terms mp3, free and convert,
Thanks again Lads for all your help. I will try this tonight!!!
