dipping passanger mirror
i just got a new octavia elegance and i read you can get the passanger mirror to dip when you put the car in reverse, but i cannot make it do this anyone got a clue what to do?
It is only available if you have the electrically adjusted seats with memory.
Standard on L&K, option on the Elegance
Hi on my superb you put the mirror adjusting switch to position ® and leave it there then when you select revers the mirror tilts down.if you have the hand book its on page 77 .bill
Yep, for the Octy2 this is the case. Require memory seats, which is a bit bizarre but there you go.
The Superb2 is a different kettle of fish :)
Steve
Steve
It needs the memory, which it gets from the seat controller to know where to put the mirror back to after reversing.
Ian
stick the selector on ® and then push down - the left and right mirror will both go down.
...But then you need to re-adjust them after every reversing manoeuvre!
you say re-adjust, but it takes seconds to move down and the same amount of seconds to move back up. UP/DOWN is the only adjustment.
it helps.
Is there a setting in the Multi Function Convenience Menu which enables this to work?
