Cruise control
I have just realises that my car has been partially fitted with cruise control. It's got the stalk/lever fitted but the previous owner didn't get round to fitting anything else.
Where's best to get the harness from?
Have seen one on eBay but it's a full kit for around £70, but can I buy the harness separate for less?
Also is the much work involved in fitting the rest?
Isn't it just a VAGCOM download seeing as you've already got the correct stalk?
Edited by Mr Ree
No you need the wiring harness to go with it. They only come with the kit but I could make one for you.
How much and how easy would it be to fit?
i got the full kit, (wiring, stalk, instructions) from TPS for £45. its not massive job if u know what ur doing, and it helps to extend the "white" wire to the ecu. then u need to enable it with vagcom. took me about 4hours to complete.
Do you have any contact details for TPS?
