O2 Sensor
Hi can this senser cause the car to go into limp mode? skoda octavia vrs Mk1
yes whats your problem with the car
Ihave error code p0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) and epc light on dash
time to change it then me thinks :thumbup:
Does it sound serious then? I thought it just needed a sensor, and some advice about it cheers.
fit sensor clear codes job done
whitch of the 2 sensors do i replace
a picture would be good if you can cheers
Bank 1 Sensor 2 is post cat sensor, the one after the cat.
Before you rush out and buy a new sensor, check the heater circuit (the two white wires on the sensor) is receiving 12V power from the vehicle when the engine is running. *edit* whilst you are under there, unplug the rear sensor and check the resistance of the sensor heater - measure the resistance across the white wires, should be a few 10-15ohms or so. It may quite possibly in this case be open circuit, so timwe for a new sensor.
It could be the sensor heater broken or could be the heater supply circuit faulty elsewhere.
Edited by richm
