Help Diagnosing - intermittent problems starting
Hi
I am hoping someone is able to help me interpret my diagnostic for my Fabia 2002.
Wednesday,17,November,2010,14:33:12:33706
VCDS Version: Release 10.6.1
Data version: 20100831
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 AF
Component: 1,9l R4 EDC 0000SG 1110
Coding: 00002
Shop #: WSC 13765
VCID: 5BBE9F37E357
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 13765
VCID: 4280425364FD
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
VCID: F2E0529394DD
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
41-10 - Blocked or No Voltage - Intermittent
28-10 - Short to Plus - Intermittent
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25754
Shop #: WSC 13765
VCID: 3A703AB30C2D
1 Fault Found:
01598 - Drive Battery Voltage
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 0004
Coding: 12338
Shop #: WSC 13765
VCID: 2044E8DB8AB1
1 Fault Found:
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y2 919 880 D
Component: KOMBIINSTRUMENT VDO V11
Coding: 16441
Shop #: WSC 13765
VCID: 4894507B42C1
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 13765
VCID: F0E4589B9AD1
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00110
Shop #: WSC 00000
VCID: 397225BF092B
1 Fault Found:
01288 - Terminal 30; Steering Assist
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 31 Komfortgerát 0001
Coding: 00067
Shop #: WSC 13765
VCID: 3D7A31AF1D03
Part No: 6Q2959802
Component: 31 Tõrsteuer.FS TFK 0002
Part No: 6Q2959801
Component: 31 Tõrsteuer.BF TFK 0002
End ---------------------------------------------------------------------
Over the last three years the car battery has been replaced three times and during the last 6mths we have had 2 new alternators.
The problems vary from having difficulty starting the car as it is totally dead and/or power steering become heavy when reversing out in the mornings and it is difficult to manoevre with warning lights appearing on the panel.
A new alternator was fitted in March and at that time a heat resistor pack was also installed for the aircon, I think this might have caused a new problem.
The aircon seems to work when driving when the control is set at 0. Also if the temperature gauge is on a warmer setting but off then hotter air blows out .
Last weekend the car wouldn't start so I charged it overnight and it has has been working well all week.
Any help would be greatly appreciated.
6 Faults Found:
1 Fault Found:
1 Fault Found:
1 Fault Found:
Sounds like a royal PITA to diagnose. Have you cleared all the fault codes since the last piece of work was done? If not, clear them, and rescan periodically and whenever anything goes wrong.
If you hadn't reported any other symptoms, I'd have said the codes were probably all caused by disconnecting the battery. However, they're all voltage-related so it sounds like you have either:
- an intermittent short
or
- an intermittent high-impedance connection (=dodgy connection - probably lose or corroded)
The intermittent nature of it makes it difficult. You're probably going to have to get friendly with a multimeter and go around measuring voltages and impedances (=resistances in this context) until you find something that looks "wrong". Then start unplugging things to isolate the problem.
Last time I had a peculiar problem like this, it turned out to be a short to ground inside the starter motor. The solenoid had literally bashed its way through the casing and until it touched the metal case (=ground) whenever I turned the key.
Good luck!
Good luck!
:thumbup:
I'd start with checking the battery leads, starter lead and engine earth strap for a good, clean connection.
Isn't there some history of dodgy connections to the fuse box on top of the battery on these?
Dunno, but I think I've heard of it with some VAG models, so possibly.
