[1.9SDi] ASY Cambelt Change / Injector Pump timing
Hi,
I've just done a cambelt change on my ASZ (PD130) engine quite successfully and I'm due to help my Dad out with his 1.9SDi Fabia (very early SDi ASY)....
I've been doing some reading and it appears that the SDi engine requires the injection pump to be setup via VAG-COM afterwards.
Can anyone verify this, and point me in the right direction for some details regarding the procedure (ie.. is it the same as a TDi?)
Thanks.
Phil.
