fabia vrs power windows
anyone had problems with fabia electric front windows? Passenger side on mine stopped working, suspected the fuse, took the fuse out and back in again and window ok for a day or two. Stopped working again, fiddled with the fuse and ok for a while. Problem is it's difficult to tell the daeler there's a fault when it's intermittent. Has anyone noticed that one fuse controls the passenger side and one fuse controls both but not the fuse numbers detailed in the handbook ???
The windows use the CANbus which reduces the number of wires. It should log faults to the ECU so your dealer should be able to hook up their diag equipment and have a look. Alternatively, find someone from here with VAG-COM in your local area who can do it for you.... :)
Chris
