New RNS510 380X Firmware
WARNING I HAVE NOT USED THIS YET AS I HAVE REVISION A UNITS. IF YOU INSTALL THIS YOU DO SO AT YOUR OWN RISK!!!!!
1. This is only compatible at the moment with VW C units and Skoda B units
2. It is a Factory install so all Maps & HDD data will be wiped
3. You require V7 Maps
4. Your unit will get renumbered:
       Skoda units become 3t0 xxx xxx B
       VW units become 1t0 xxx xxxx D
5. You may need to recode with VCDS
Whats Different
1. New Poi Feature (which requires V7 Mapping)
2. Long Press of Setup reveals a menu that says.
          FM
          AM
          VERSION INFO
3. New Compass
4. Lots of Bug Fixes
CDInfo
#CD:P 0 0 5 . 1 5 0 . 3 0 1
#DATE:2010-11-19
#Project: VWRNS
#Author: RoNe
#Steckbrief: C_EU_10.341_t2 C10/C6
#CommentStart:
This is a SWL CD for VW delivery.
#CommentEnd:
#Integrationphase: Delivery cw22/11 C10/C6-samples
#VwSwPartNumber:1T0035680D/1T0035680D/7L6035680C/3T0035680B/7F0035680A/7E0035680A/1T0035680F/1T0035680G
#VwSwIndex:3800/3806/X999/3808/3804/3800/3800
#AppsBuild:C_EU_10.341_t2 C10/C6
#CRC16:4b35
Download Links
http://car2diag.ru/download/other/3800-04-06-08.iso
http://upload.com.ua/link/902151122
I have the .iso image on my computer and i have had a look at it. It does appear to be kosher. It is a lot larger than normal at 654MB. As i said earlier if you install you do so at your own risk.
Enjoy :thumbup:
wait Simbo for moded 3800 fw..maxi+mfsw+test mode :)
The Firmware hasn't been modified yet and it might be difficult to do so according the guy who normally does it.
hopefully it will josi or symbo to find a solution ;)
Carl, my unit part number is as follows, is this a version C because of the suffix A at the end and its a feb 2010 unit
PART # 3TO 035 680 A
HW - 04
SW - 2680
Edited by The Skud
No mate that is an A Revision I'm afraid.
The reason it says 3T0 is because when you flash an A Rev with 0904 firmware or Higher it changes the part no from 1Z0 to 3T0
The only Skoda ones it will work on at the moment are
3T0 035 680 B which are usually found in the Superb and FL Octy (factory fitted)
That's a bit confusing because the Part number is not off the unit screen its off the actual original label on the unit and is a Feb 2010 unit I haven't got VCDS yet to check the info on the unit it actually has 3TO printed on the unit label
I think I have a Ver B unit as it is out of a superb but need to check.
Any chance of a modifield Ver for the FL cars?
I dont want to lose my video in motion by going to a factory version.
Yes, it is true version C unit.
Anyway, I don't recommend this firmware to anyone - it is a leaked beta version, with few visual glitches already noticed. It does not add new functionality, except the additional language support, so it will be better to wait the final version which should be available after week 22/2011.
:dull: :dull: :dull:
Hello,
I'm Crum des present in Spain, wanted me to clarify a doubt about the firmware modified by Simbo is valid for a drive VW
Part No SW: 1T0 035 680 C HW: 1T0 035 680 A
Component: RNS-MID H04 2660
Sorry for my English
No, la versión modificada es sólo para la pre-fl Skoda Octavia rev B unidades. Pedimos disculpas por mi español, la culpa Google Translate! :giggle:
Bienvenido a Briskoda! :hi:
Thanks for the welcome. :D
You can change the firmware so it could be used with the version "A"?
Cool, I bought better than I realised then! :rofl: if it really is a version C then I got an absolute bargain when I bought it anyway if the update does not add any functionality I'lll leave it as is....its perfect now anyway running V7 Maps! :thumbup:
Hello,
A question for the experts. I have a version "A" RNS510, I can not load the firmware 3800 with the Spanish voice control. It would be possible to make a mix with a 2720 with firmware files "SPEECH" to the Spanish language? It's crazy what I am saying?
THANK YOU
Hi,
I have a 2008, 58, Octavia estate. How can I check what version of Columbus I have?
I've just realised that it won't play SDHC cards so I've decided to upgrade it if I can!
Thanks for any links to guides on how to do it.
Cheers,
Lou
Hello,
THANK YOU
It won't be possible.
so it seems. thanks
Regards
@simbo, there is newest firmware 3810
community eagerly awaits your new project..moded 3810 B)
link original 3810
http://fayloobmennik.org/a0ko16kmwqv1.html
3810 is still a pre release Beta though so be careful and expect bugs.
Would someone be kind enough to make a table showing which firmware versions are compatible with which Columbus versions?
I've been thinking to upgrade mine, to take advantage of SDHC support, but don't want to risk breaking it! If I knew my options it would make life easier.
  • 1 year later...
thank you for the post,
i got issue my unite is become D but it actually B
so i can't copy the Map to the Device
can someone please advise?
Delivery Part Number : 1T0035680D
HW version :H02
SW-Version : 3810
