Superb I washer connector broken
Today I have discovered that my Superb Front windscreen washer pipe has popped off. I see that other folk in other threads suggesting about fishing around for the pipe and reconnecting it. Is there an easier way to access the tubing in the inside of the bonnet lid?
Please help as I currently have no washer working! :'(
Er........................ no !! Take off the plastic covers and all will be revealed, take care not to break the T piece.
As stated above this is a simple 5 minute re-work activity and something that will always happen in these winter climates.............. :yes:
1) Under the bonnet you will find two black plastic oval bungs near the washer jets, remove these with care, they are tough but will come off;
2) The driver's side one will be the one not working so you will need to unclip if from the bonnet, this simply rocks out of location, also do this for the passenger side one;
3) If you half remove the driver's side one you will see the right angled hose clip that has come undone, go to the passenger side jet and half remove this one, by doing this it you will see the end of the hose in the driver's side hodl window, grab it, reconnect them together and then re-fit everything back together.
Hope that helps................ended up doing mine yesterday............ :thumbup:
