leaking wiper reservoir
Hi I have a leaking wiper reservoir, it leaks when filled straight away, through & down the front offside mudflap/wheel arch
Anyone had this, experience of fixing helpful, as i can't easily see a way to access the reservoir to determine if it's split/cracked
or a hose has come adrift
thanks
To fix, there's 3 screws in the wheel arch, near the front of the car on the outside. Undo those and you should be able to fit an arm through to push the connection together again. Although the other link above may have a more detailed guide than that.
Hope it sorts it.
Hang on..... front OFFSIDE???
Didnt know the screenwash pipes ran near there.
Unless you meant Nearside (Passenger side)??
I was referring to the passenger side (of a RHD car), if that's not what the OP meant (assuming he's RHD) I have no idea!
