accessing washer bottle connections
[anybody know how to get at the pipe connections on the washer bottle , I need to check the connections , I have water to the front washers but not to the rear washers. I am also loosing coolant when I operate rear washers but no sign of where it's going!!
If the washer pump is making a noise when you spray the rear window, first check the boot floor near the CD changer. If that's dry check under the driver's side of the car for a pool of washer fluid.
Mind you this is the octy forum, your details say fabia?
I have said pool under drivers side, has it popped off the bottle?
