VAG-COM chichester or surrounding areas
Hi all,
Just purchased cruise control unit and am awaiting it at the moment.
I have been told that it has to be turned on using a VAG-COM or similar, is there anyone in my area that could give me hand as i dont own one!!
Thanks in advance.
James.
I think Cheezemonkhai is in the Gosport area if your willing to travel a little bit :thumbup:
I am also looking for someone in the Chichester/Portsmouth area for a Throttle Body alignment.
I have VCDS and can help out. Do you know how to do a TB allignment? I haven't done one before but happy for you to use my kit.
Great! Im not sure but ill have a look as well but as James said im sure we can work it out.
Edit: The link that James has provided says it all (I should of checked it first) :doh:
Edited by TommyJ_VrS
Yeah I'm around that way for a while yet if you do need it enabling and you the other guys can't help you out :)
Hi
I have full VCDS if required
Im not sure about throttle bodies and the cruise control but i have the kit
Only the hex key tho - mk1 octavia and mk1 fabia only
Im based in oving if anyone needs a hand
tom
