Heater/Aircon Max button
Hi All,
When I press the 'Max' button on the heater control panel it doesn't put the fan to maximum I have to press the + maybe three more times to get the fan to max is this normal or is there a reset to put it right.
My dash is the same as the FL I have been told.
Darren
Your LE has the same climate control as the FL Octavia, Yeti and Superb.
When I press the max defrost button my fan doesn't run at full speed, all the button does is quickly divert all airflow to the windscreen when pressed and run the fan at 2/3 speed.
Whats the point of putting 'MAX' on it if it only gives 2/3. If I want to clear the windscreen first thing in the morning full power is going to clear it quicker, it just seems to be an half arsed button :)
