Upgrading Bolero in SE model
Does anyone know if the Bolero can be upgraded in the Yeti 2.0 110bhp to enable you to have bluetooth. There appears to be the buttons on the steering wheel so does anyone know what would be needed to enable the phone function to work on Bolero.
You need to have the bluetooth GSM11 preparation fitted. I believe it can be fitted, but it isn't cheap. Terfyn looked into it a while back.
Mike
It's nuts isn't it that it isn't enabled as standard.
After all it's an important safety feature these days. I wish manufacturers would treat it as such instead of an exorbitant optional extra! I just ordered an S model and the only thing I'm not looking forward to is doing without the inbuilt bluetooth that I've got used to over the past three years.
Stouff
Mike
£300-£400 depending on the steering wheel!!!!! Yes the wheel needs changing.
Get a Parrot device fitted, or equivalent. They are around £100-£150 fitted and they work brilliantly. I have one and transfer it between cars each time I change.
