Plastic plugs for wheel arches
My wheel arch plastic protectors have dropped and are rattling away on the links and drive shaft due to the plastic plugs snapping, how easy is it to realign and get them back in place, and does the back bit go behind the front at the joint next to the shocker
Edited by skippy41
The wheel arch liners will be refitted today :thumbup:
Well had the liners refitted, then found out one of the floating pins on the caliper was loose, and would not tighten up, as the thread on the carrier was worn, so the garage said they could insert a coil something or other, after re taping and making the hole slightly larger, this would save replacing the hub, they fitted a new pin with lock tight until they can get the kit
