Control system for exhaust warning light
Hi,
I am having Skoda Fabia 2005 model in Finland.
One day windscreen wipers were not working (fuse 15 broken) probably because of too cold here.
So I was replacing the the fuse and probably I made a mistake in the fuse panel.
I took one 10 amp fuse but forget from where I took.
After that I am seeing Control system for exhaust warning light is ON constantly.
So do you know how I can check if there is any missing fuse from the fuse panel?
And on the road there is lots of snow, can it be because of snow ?
Any help will be accepted gracefully.
Regards,
BT
Can't you just compare the diagram in the manual with the fuses in your fuse box? Being a LHD car, they should all be in the correct order and everything! :thumbup:
Otherwise, you can use this:
http://www.fabia-vrs.com/technical-info/fuse-panel-layout/
...and convert it to a mirror image in your head like we in the UK have to do with the manual which shows the layout for LHD cars!!!
