nightmare
Engine manegment light showing crankshaft sensor fault have changed this with approved part but still cant clear fault its going in to Skoda dealer in two weeks ,the car starts ok but is running in limp mode.The car model is 2.5 tdi superb 2007 just wondering if this fault has happened before.
Whats the faut code.
well it comes up with different ones depending on what comp they have used but they all relate to the same thing crankshaft sensor or speed sensor which they say are the same it seems they are hunting a electrical fault or something to do with the ecu or flywheel
Make sure it is clear if you need a cam position sensor or a crank position sensor :wonder:
Thats helpfull are you saying there are both sensors on this car then as isee you have the same one.
