Technical changes to the Yeti MY10 & 11
The Plumber
Recommended Posts
Having spent the past week or so browsing through the parts 'book' when I have a spare minute, besides noting the origin of these parts (see DNA thread) I have also started to catalogue changes in part numbers or components that suggest an update or technical change has taken place. Some clearly are on cost grounds particularly affecting the 2wd models from MY11. Also noted some part numbers are already listing obsolescence at the end of May 2011, which could suggest forthcoming changes for MY12; Columbus being one such component :wonder:
Technical changes to the Yeti since launch
Engines
September 2009 – CBZB 1.2TSI introduced
November 2009 – CBAB 1.8TSI 152bhp introduced (Believe used in Russian market)
November 2009 – CFHA 2.0TDI CR 110bhp engine introduced (2wd)
November 2009 – CFHF 2.0TDI CR 110bhp engine introduced (4x4)
November 2009 - CBDB 2.0TDI CR (140) engine replaced by CFHC 2.0TDI CR (140)
May 2010 - CEGA 2.0TDI CR (170) engine replaced by CFJA 2.0TDI CR (170)
May 2010 - CLCB 2.0TDI CR (140) engine introduced, manual transmission only (Indian market)
June 2010 – CAXA 1.4TSI 122bhp engine introduced
November 2010 – CAYC 1.6TDI CR 105bhp engine introduced (GreenLine II)
09/11/2010 – update to engine fuel pump 1.2TSI
Gearboxes
1.2TSI
September 2009 – LHA 5 speed replaced by LHX 6 speed
May 2010 – MGU 7 speed DSG replaced by MLJ 7 speed DSG
November 2010 - MLJ 7 speed DSG replaced by MPQ 7 speed DSG
April 2011 – LHX 6 speed to be replaced by NBY 6 speed
May 2011 – MPQ 7 speed DSG to be replaced by NBA 7 speed DSG
1.4TSI
November 2011 –NBY 6 speed to be replaced by NBX 6 speed
1.8TSI (152bhp)
May 2011 – NCN 6 speed DSG to be introduced
2.0TDI CR (110bhp) 4x4
May 2011 – LNN 6 seed to be replaced by NFQ 6speed
2.0TDI CR (140bhp) 4x4
November 2010 - MMJ 6 speed DSG replaced by MUA 6 speed DSG
May 2011 - MUA 6 speed DSG to be replaced by NJC 6 speed DSG
May 2011 – LNM 6 speed to be replaced by NFR 6speed
2.0TDI CR (170bhp) 4x4
May 2011 – KXY 6 speed to be replaced by NFM 6speed
Clutch
12/01/2010 – Update to Sachs 240mm clutch CEGA 2.0TDI CR 170bhp engine
12/01/2010 – Update to Sachs 288mm clutch CFHA 2.0TDI CR 110bhp engine (2wd)
01/06/2010 – Update to Sachs 240mm clutch 1.8TSI
Gear selector
31/05/2010 & 06/12/2010 – updates to DSG selector
08/11/2010 – update to gearstick knob and badge manual transmission
Fuel system
31/05/2010 - 60 litre saddle fuel tank (designed for 4x4 systems) fitted to all models from launch replaced with conventional 55 litre fuel tank on 2wd versions.
Exhaust system
05/04/2010 – 1.2TSI change to catalytic converter
31/05/2010 – 1.2TSI change to centre and rear exhaust design
31/05/2010 – 2.0TDI CR (110bhp) 2wd change to DPF
01/06/2010 – All TDI CR 2wd change to centre and rear exhaust
Front suspension
02/08/2010 – Front assembly carrier, wishbones and rear wishbone bearing replaced with new designs.
Rear suspension
31/05/2010 – Tiguan 4x4 support frame used on all models from launch, replaced with simplified FWD Golf V rear support frame on 2wd models.
Brake systems
02/11/2009, 31/05/2010, 12/09/2010 and 08/11/2010 - Updates to ABS/ESP (depending on model and equipment).
19/10/2009 – update to 280mm front brake disk
02/11/2009 – Lucas? 286mm rear disc and calliper replaced by Bosch 272mm rear disc and calliper (effects 1.8TSI, 2.0TDI CR 140 & 170bhp).
Electrical Systems
02/11/2009 – update to climatronic control operating unit
02/11/2009 – update to off-road button
02/11/2009 – update ECU 1.8TSI
02/11/2009 – update Columbus navigation system (were fitted)
02/11/2009 – update front headlight range control
01/04/2010 – update xenon light control unit
02/04/2010 – update to sparkplugs 1.8TSI
31/05/2010 – update to climatronic control operating unit
31/05/2010 – update to ignition leads 1.2TSI
31/05/2010 – update to ignition switch
31/05/2010 – update starter 1.2TSI DSG
31/05/2010 – update to fuel delivery & sender unit diesel engines (located in fuel tank)
31/05/2010 – update onboard control unit
31/05/2010 – update data bus interface
31/05/2010 – update rear headlight range control
31/05/2010 – change in design to steering column controls
07/11/2010 – update to control unit front/rear park aid (were fitted)
08/11/2010 – update data bus interface
08/11/2010 – update to climatronic control operating unit
08/11/2010 - radio aerial design change
01/12/2010 – update to sparkplugs 1.2TSI
01/12/2010 – update to glowplugs (all diesel engines; BERU version)
06/12/2010 – update to alternator bracket (all diesel engines)
01/01/2011 – update to camshaft impulse sender 1.8TSI
30/05/2011 – update to climatronic control operating unit; update not listed
30/05/2011 – update data bus interface
30/05/2011 – change due to Columbus navigation system (were fitted;) update not listed
Under-body protection
02/08/2010 - update protective floor cover panels
02/08/2010 - RRP design change (where fitted)
TP
Link to comment
Share on other sites
  • 2 months later...
I have 2.0TDI CR (140bhp) 4x4 with 6 speed DSG.
Do you have any further information on the change "May 2011 - MUA 6 speed DSG to be replaced by NJC 6 speed DSG"?
Is it significant?
Link to comment
Is it significant?
Unfortunately no further info at this time; listed as an up and coming change in the model and transmission overview in the electronic parts system.
Regards,
TP
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
