engine wont start after cooling
Hi all
Recently had a problem starting my fabia 1.4 after the engine has cooled
Usually starts OK from cold or from warm but leave it an hour and the engine is flooded.
Removing the fuse for the fuel pump and turning the engine over starts the car.
I let the engine cut out before reinserting the fuse and the engine starts.
Recently had a full service and lamda sensor as an engine management light code
was reporting a fault.
I'd hoped this might have fixed the problem but unfortunately not.
Any suggestions would be a huge help.
Many thanks
Tim
Edited by Timus
Sounds like a problem within the fuel pump, Any chance you could try a new pump on it? Is it a 1.4 petrol?
Hi thanks for the response.
Not sure I could try that without buying one. Are they expensive?
I found a post about a Felicia which mentioned potential choke problems
Could that cause it to flood?
