VRS - engine noise - help required..please.
Hi,
I have a 2005 Fabia VRS with 87k (80% motorway miles), It has full service history by my self, serviced every 10k (works out to be every 5 months).
Recently the engine has developed a strange noise, its not metalic or from the driveline, it sort of sounds like an extended exhaling moan, its hard to describe. The noise is can be heard between 1250-2000rpm when comming off the throttle at low speeds, but can also be heard when crusing at motorways speeds under acceleration in 6th.
I'm a little baffled to whats causing it, I shall try and take a video tomorrow.
Has anyone else had this issue or have any ideas to the probable cause?
Any help will be greatly appreciated.
Mat
  • 3 months later...
Just incase anyone searches this wondering what happened in the end,
I changed the oil as I normaly do with genuine VAG oil ordered against my VIN and the problem has gone away. Simples!
