Front Hubs - Brake conversion
I know to go VRS brakes or TT 312's I need vrs hubs. However there must be other hubs that are same, polo gti mk5 I belive are same as they are same brake setup. Whatelse as VRS hubs are pricey as you like!
The part numbers you need are:
O/S Bearing Housing (hub) 6Q0 407 255 S
N/S Bearing Housing (hub) 6Q0 407 256 S
Wheel Bearing 6R0 495 621 A (need two of those obviously).
Try getting that priced up at VW as well as Skoda, they were able to give me a better price and I'll be ordering them very soon.
Of course, your other option is finding the bits on a scrapped car if you're confident enough to do so.
Hope this helps!
Andrew
TDI fabia brakes are bigger than the 239mm so they on same hubs as VRS? Do TT hubs fit?
Cheers for part numbers buddy, Im a tight arse so scrappys for me and play the waiting game. (I have the 312mm TT brakes in my garage off my TT, thats now running GT2 6pots)
Edited by Bikerz
The TDi Fabia uses 256mm front brakes, but unfortunately the hubs are different, hence me ordering some up! The TT is on the Mk4 Golf platform so I highly doubt the hubs off that will fit.
No problem mate, and good luck :thumbup:
Edited by Leodhasach
TT is a mk4 golf platform correct. So fabia vrs hubs are a one off and not found on anything else? I find that hard to belive? Octy VRS hubs same too tho I presume?
Octy is same platform as a mk4 golf so doubt they would fit. You need fabia vrs/2.0 or polo GT or ibiza fr/cupra i think
Matt
Cheers Matt. Just found out Octy hubs same as TT so that will be mk4 as you said. I presume you mean polo GTI 1.8t? Seatcupra forum say about the 312's so they seem a good shout, thank you.
The VRS 288mm setup also comes on what cars? The above? Polo GTI 1.8t? Leon and ibiza?
