central locking
hi all i was wondering if anyone could help me the central locking has went nuts again and my local garage is telling me i need a new control unit.the thing is i pulled back the rubber cover from the door to the a pillar and had a rummage about,now i found if i move the blue and black wires i can hear a relay clicking behind the dash and the central locking works again.my queation is what are thoes two wires and where do they run to once they have gon through the a pillar
thanx in advance
rob
Edited by bobbytodd
IIRC, the only blue wire in the loom is one of the speaker wires. The most likely candidates are the Red/Yellow and Red/Brown wires. These may be getting pulled when you move the other wires.
What is the problem?
Either way, this is sounding a lot like an internal break on one of the wires in the A-post to door loom, which IIRC is available separately from about £15. You could do a continuity test first, but a multimeter is also at least £15 if you have to buy one.
sorted it turned out to be a break in the thick orange wire running from the plug so it was just a case of putting a new length of wire in
Unless someone has replaced part of the loom, there is no orange wire, so I assume it was Red/Yellow.
could have sworn it was orange.ah well specsavers for me tomorrow.anyhow it was a nice non expensive fix so im a happy bunny now.there was wiring for an after market alarm and some other wires from its pervious life as a police car
Edited by bobbytodd
