gearbox problems
Hi guys has anyone else had problems with second gear on a vrs pd130 when starting from cold it crunchs into second but after a little way down the road its ok is this anything to worry about
i think most are notchy when cold mine used to be there is some better gear oil that you can get from your dealer the oil is for a TPI on 5 speed gearboxes for hard gear selection i put this oil in mine and works a treat
