Air con drain tubes
Has anyone cleaned out their AC drain tube?
Either from inside the car or underneath?
Took some of the centre console apart today and was expecting to see one but couldn't see anything obvious.
Or is it easier to clean it out from underneath?
It comes out the very bottom of the heater box in the middle and runs down the drivers side. You can see it if you remove the side panel of the centre console. They wont block up, sometimes they arent fitted from factory properly but it isnt long before that becomes apparent.
How do you get the side panel fully off?
Found one obvious T20 in the footwell.
Then another behind the ashtray, but it still felt like there was one I missed - Maybe behind the stereo?
Once those two are out you pull the bottom out where the foot rest is then the whole lot slides forwards into the footwell.
OK thanks.
Didn't feel like it wanted to come out and didn't want to break anything. Guess I'll just give it a bit more force!
Which direction does it pull out? Downwards or towards the back of the car?
As I said, forwards into the footwell
