how 2 remove wing mirror indicator
This might be a simple job for some of you peps but is there and how 2 guide or a simple way to remove and refit the indicator in the wing mirror.
Edited by rob octavia
Yes its easy if you know how, 1st pull your wing mirror cover off theres no fixing screws it literly pulls off (sometimes it can be very tight but just pull and ease it off the retaining clips) Leaving the mirror glass on. Then if you look inbetween the mirror glass and the back you will see 2 very small torqz screws undo them and the indicator housing will come off. Rebuild is in reverse :thumbup:
thanks alot i will go and try that now
Alsorted thanks sherlocks easy when you know how
