kkk ko4 turbo
hi all, was looking on ebay and there is new ko4 turbo's!!
was thinking about getting one..... they are coming from germany and they are the standard ko4!
would i see much gain on the octy vrs! car is remapped and runnning at 15psi
would i be better getting the ko4 and the 4 bar fuel regulator and a new remap?
remap i have is a superchips one :eek: :rofl:
but they did not get gains like some of you guys got through jabba!
thanks for ur time
What K04 is it? Is it a 210/225 turbo or a modded one that will fit on a Octavia vRS?
yeah its the standard 210/225 ko4
can i just confurm that the k04 will bolt onto the k03 manifold?
read on a cupra site they did.
wont fit.
why wont it fit?
which parts need changed?
woudl i be able to change the manifold also.
this is wher ei got my info from
TURBOCHARGER
I knew a big turbo conversion was not going to be possible for me - why? Mainly because there is only one place in the whole of the UK that does big turbos for the 1.8T - Jabbasport, and they are 300 miles away from me so that was out immediately. The only other option available was moving up from the factory K03S turbo to a K04 turbo. The K04-001 turbo is a straight bolt on replacement for the K03S and usually offers around 250BHP and 270lbft of torque - for around
there is a speacial k04-001 turbo for use on auq engines..
the std one from a TT/Leon/Passat doesnt fit.
The manifold and down pipe are different for the K04 on the 210/225 engines.
so what needs done to put a k04 on in place of the k03?
without spending a fortune?
Fit a K04 that has been made to fit the AUQ engine.
Try here...
www.am-motorsport.co.uk
and then remap it.
uprate the clutch
uprate the gearbox
uprate the suspension.
you WILL need to.
