Auto Start-Stop not functioning
This old chestnut seems to have been a re-occurring theme on BRISKODA forums, with various Skoda models affected although I couldn't see any reports from Mk4 Octavia owners; hence this new topic.
I've had my vehicle just over a month now, so it's 10 months old with 6200 on the clock. For the first few days the auto start-stop (ASS) worked as expected, but now, for some reason it never activates. Having read other users reports, it would seem a battery issue may be the likely cause. I've tried driving without any extra drain on the battery i.e. heated steering wheel, air con. etc. but to no avail. I didn't purchase the car from a Skoda dealer, so I'm assuming that all the pre-sale checks carried out by the seller (Cinch) may have included a battery charge as standard..
Have any Mk4 owners experienced this issue and if so was there a successful resolution?
Any input would be most welcome before I make a visit to my local Skoda garage.
Many thanks in anticipation.
Charging the battery: if this helps only temporarily, replace the battery regardless of age or mileage.
What type of use does this car get - is it mainly used for short runs?
There isn't normally a lot of headspace between the battery SOC level that the smart charge alternator maintains and the SS cut-off level, plus SS won't be available if one, of at least 6-8, operation parameters are not met.
Edited by Warrior193
correction
Mine does it too and according to my main stealer it’s because the car isn’t used enough to keep the battery fully charged. Bear in mind these days that even if the car isn’t used just sat there it will have something somewhere using a bit of power. I just give mine a 20 to 30 min run every couple of weeks
I'd strongly recommend getting the battery fully charged and properly tested before replacing it - and test the alternator output.
added information
