Fault code 18009
Monday, 14 February 2011, 18:40:15.
VCDS-Lite Version: Release 1.1
Control Module Part Number: 038 906 019 NF
Component and/or Version: 1,9l R4 EDC 0000SG 7000
Software Coding: 00102
Work Shop Code: WSC 13765
VCID: 68A33BA31B7D
Additional Info: TMBWU46Y754292216 SKZ7Z0E2809348
1 Fault Found:
18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
P1601 - 35-00 - -
keep getting the following fault code , windows also dont work on car so im hoping its something to do with this anyone know what it means
Have you checked all the fuses?
hi yes all fuses are ok, windows would only work when battery was removed and put back on untill you locked the doors then unlocked got back in car and windows wouldnt work now they dont work at all, and the same old code just keeps appearing minutes after its been cleared so definatly a problem with it not sure what to do and im stuck with a car with no windows working its a 05 fabia vrs by the way
any one really struggling with this, ive changed both electronics control unit and conveince unit and still windows dont work properly and get the same error code keep popping up
Have you checked the alternator harness, especially where there is a plug attached to the front of the gear box. A code read of just the engine will not show the whole picture if you are having problems with the windows. A complete autoscan will help.
Herers the complete scan ive replaced both conveince and electrical control box and both windows still not working
Saturday, 26 February 2011, 11:10:30:173
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine Labels: 038-906-019-ASZ.LBL
Controller: 038 906 019 NF
Component: 1,9l R4 EDC 0000SG 7000
Coding: 00102
Shop #: WSC 13765
VCID: 68A33B0E1B7D
1 Fault Found:
P1601 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 AB
Component: MABS 8.0 front H03 0001
Coding: 0000008
Shop #: WSC 13765
VCID: 7D8D7A5A64FF
No fault code found.
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F297D966ADA1
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.LBL
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25754
Shop #: WSC 13765
VCID: 3C0BB75E3F65
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 601 A
Component: 11 AIRBAG VW51 0008
Coding: 12593
Shop #: WSC 13765
VCID: 1E4F5DD689B9
Address 17: Instruments Labels: Redir Fail!
Controller: 6Y0 920 971 Su
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 28401
Shop #: WSC 28008
VCID: D7C188F22603
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: 003D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
VCID: F093D36EA3AD
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ssu
Component: e 17 eingeben
VCID: CFD170921ED3
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 44: Steering Assist Labels: 6Q0-423-156.LBL
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
VCID: 6F9150123E93
Address 46: Central Conv. Labels: 6Q0-959-433.LBL
Controller: 6Q0 959 433 E
Component: 60 Komfortgerát 0002
Coding: 00018
Shop #: WSC 13765
VCID: 3D0DBA5A247F
Address 56: Radio Labels: 1U0-035-156.LBL
Controller: 6Y0 035 156 C
Component: Radio 0007
Coding: 00401
Shop #: WSC 13765
VCID: 361FA5760149
End --------------------------------------------------------------------------------------------------
Are there any faults shown in 46 if you introduce a fault, such as disconnecting the drivers door control unit?
I had similar on a 57 plate Roomster the other week. No faults, no faults with the drivers door control unit disconnected and intermittent window operation shortly after reconnecting the battery. I took a guess and replaced the drivers door control unit which fixed it.
  • 4 months later...
Sorry to drag up an old thread! but did you sort this?
What was the problem?
Is it not in the title? RELAY FOR SUPPLY VOLTAGE?????
