How to remove dash caps
Hi All,
I own a Skoda octavia 05 model. There are 3 spare caps between the light of the Airbag Off and the Traction Control light.Is it easy to remove a cap? Do i need a special tool to do so?
Thank you guys
Pretty sure that if you pull the radio surround facia off and then remove the climate controls that you can pop the blanks out fairly easily.
Easiest way to remove the radio surround is to half open the ashtray, then get your fingers behind the fascia at the bottom, and pull firmly.
thank u mate i will try
