Steamy windows again
hy all,
i took the car to citygate skoda lonon because all my windows were steaming up.the diagnostic is :DRAIN HOLE WAS BLOCKED PLANIUM CHAMBER HAD WATER NOW UNBLOCKED.
I took the car home and after a few miles it started again to steam up.i realy don't know what to do or where to take the car .
pls if anyoane can help me
cheers
hy all,
cheers
have you checked rear door seals?
mine kept steaming up and when i checked the rear seals they were p****d through. no misting since resealing the doors and running aircon or window slightly open (acts like a chimney sucking moisture out) for a week or so
:thumbup:
my aircon doesn't work because need's regasing.could it be from the aircon?
i'm going to check the door seals tomorrow.the guys from skoda said that they have pressusrised the car and there is nothing wrong.i realy don't know what to do
im not sure on the aircon front but with the seals just check them after or while its raining. if they areleaking you will see beads of water sat on top of the seal which you can see next to the plastic trim of the footwell. the water then runs of the top of this seal into the footwell. carpets may feel dry to the layers of the carpet, top feels dry whilst the under layer(s) are soaked.
easy and cheap to sort if it is that
i just have pressed realy hard on the back carpets but nothing ,they are realy dry.but i just rembered something.when i bought the car about 3-4 weeks ago the carpet from the passanger side was realy wet,but i put the blow drier for about 1 hour and it dried.now it's still dry
Edited by baubauro
think theres a filter under or behind the glovebox (mentioned in that thread) that gets clogged and lets moisture in. could possibly be letting a lot in?! i'd message the guy that posted that reply in the other thread and ask his advice on that, its the only thing i can think of. have you got a sunroof?
no sunroof
no sunroof
ok. could be that filter thats letting moisture in, over time it wet the floor??
what about the spare tyre well is that dry? also check the seal that runs round the boot. in my dads fabia there is water on the "dry" side of the boot seal. car stinks and is always fogged up. it also had the rear door seal problem but that got sorted. could be the boot?
i'm just wondering if i buy a car interior Dehumidifier,or a Moisture Absorber Trap will it do the job
Think I'd get my aircon re-gassed if I was you ... nothing dries air better than a cold heat exchanger to make the moisture condense out of the air before it's re-warmed again.
This is simply down to the good old water ingress issue the MKI Superb suffers with.
When the plenum chamber flooded (due to the grommets being blocked) the pollen filter seal will have failed, this floods the N/S/R footwell (this is where the CCM lives that controls the interior lights, puddle lights etc) take a look at this blog for the cure.
(Note the Fixing Passat Leak link in the blog no longer works, either click on the new link in my last comment or here)
I'm going to have a look at Polen filter seal in the weekend.where can i buy a new seal from?.and when i'm going to take the passenger chair out does the battery need to be disconected because of the airbag?
The new replacement (upgraded) seal can be bought from either a Skoda or VW dealer (B5.5 Passat), alternatively you can do as I did in the blog.
The battery disconnection should be the first thing you do (and the last job is the re-connection), just follow the blog, make sure you REMOVE the grommets though, don't just clear them out for them to block again!
I had a mechanic comming over,he looked at the seal from polen filter and was ok.he took out the carpet from passanger side,everithing was dry.regassed the aircon.now i got the steaming windows when i press the econ button.everyting it's steaming up after i press the econ.any suggestions
My understanding of the system is the air-con is switched off in econ. You should run the car in auto for a while to remove all the moisture from inside the car.
i think that saturady i'm going to remove the back carpets to have a look for water.i removed today again te front passanger carpet and still dry except just a bit of condesation but nothing major i think.
i just took out today the front passager carpet and the driver's one but still nothing.everything dry.How can i check if the heater is on circulation or fresh air.and how is supose to be?
cheers
Did you check the rear footwells as well? as this is where the water will end up.
Look for Icon No.5 - Air recirculation display on the climatronic display so see if yours is activated (this is activated/de-activated by pressing No.18 - Recirculating air button)
how can i look under the back carpets without taking the front seats off
I don't think you can, you may be able to lift the rear corner of the carpets once the rear seat base has been removed see post #4 & 5 here to see how to remove the seat base
Behind passager's side it's realy damp an it's a bit of water.after 2 houres and after almost breaking 2 of my fingers i removed the back carpets and dried everything there.i took the car for a spin and still the same ******* problems with condesation
Edited by baubauro
one tiny question about for the polen filter seal.After you apply a thick bed of sealant do i have to leave it to dry and then fited or put it back while is wet.cheers
You need to remove the old useless seal (the outer seal of the pair) clean the recess it sat it then apply a really nice thick bead of sealant (as wide as the old seal but thicker) then refit it all together whilst the sealant is still wet, once cured this will provide a water tight seal that (providing you have used a decent sealant) should last for many years.
today i just have my mechanic over and he replace the seal that has broken and soaked of water.it only took him about 30 min to do everything.hope it will be k now.
THANK YOU GUYS FOR ALL YOUR HELP
Edited by baubauro
