recon or new rack ?
friends felly is in need of a new steering rack - there is play in the inner rack (pinion gear worn i think). the tie rods are also relatively knackered. The pinion adjuster is maxed out and there is still play. (its not power steering btw)
Went down to local factors, can get a "as new" AMK recon rack for £35, or who-knows-what at skoda dealership.
anyone have experience with recon racks? AMK ?
also - was recommended by someone that no matter what i get it would be well worthwhile really packing grease into it as they are usually pretty stingy at the factory / recon place.
thoughts?
AMK is a brand supplied by a lot of motor factors for items such as CV joints and steering racks. We had one problem with a rack for a Vectra some years ago (it may have been AMK), where the track rod ball was tight in its socket which resulted in the track rod fracturing.
In my view a recon rack at that price would be better than a second hand one for a little less. Personally I've fitted racks from motor factors to my own cars and never had any problems.
If you're feeling brave, I believe Tom did a thread on replacing non-PAS with PAS ;)
i did ask them, but they want the cheaper alternative ;) i would have enjoyed the challenge though :giggle:
ahh dammit i threw a steering rack in a skip a couple of days ago.. never mind :wonder:
^^^^^ is always the way.
the law of sod in action again..
well, swap is done. what a stupid place to put the rear clamp botls though :D
thank god for my dads 1/2" UJ ! (i dont have one lol and i could not figure out a way of removing the rear bolts without one lol)
yeah it's a right royal pain up the keeshter having to drop the subframe to get the steering rack off
Tom, i cannot believe that you of all people do not own a 1/2 inch drive UJ for sockets etc! :o
i didnt have to drop anythhing with the UJ - was still a pain in the rear though (had to bend all funny)
yes you must have little fingers like japs, it can be done without dropping the subframe on the non-pas models, but access to the fluid unions is really tight on the pas ones
no i got big manly hands thank-you-very-much :rofl: in all seriousness, it was a pain getting the socket to stay on the rear bolts, even with the UJ, and i was sorta half in the bay with one leg in the air. was a proper comedy look i reckon :thumbup:
the only diffucilt bit now is getting the steering wheel 100% straigh, its ever so slightly cocked to the right, butmoving the wheel one spline is too much. and yes, i did properly centre / align the rack and i got it tracked at the same place i entrust my MR2 with, and it drives straight and proper, its just a little wonkey. hmmmmm - any ideas?
by the way i changed the whole lot - recon rack, new rod ends and rod end locknuts :thumbup:
IDEA : can i correct the wheel by adjusting each rod end by say 1/4 turn and see? as its cocked to the right i think drivers side come in 1/4 and passenger out by 1/4
would that work?
Edited by poorly_felicia
yes just tried to post, wind one end in, and wind one end out but i got a dropped connection so it didn't work i think
cool, thanks! how much tolerance is there you think (im bound to spin the tie rod a little when i undo the locknut) before its re-tracking time again? would 1/2 turn each side difference make no real significant difference or is it tighter than that?
