Autoleads PC6-050, HELP
Just recieved my Autoleads PC6-050 lead to connect my hands free kit to the radio. The car is an 04 Octy vRS with standard head unit. The instructions mention about a radio mute lead and checking which is the permanent and live feeds?? Basicaly can I plug the :confused: lead straight in or does it need configuring.
Adam
Should be able to plug it straight in mate...
If your battery goes flat then you have the switched and live round the wrong way:D
You need to look at the pinout for the octy ISO power connector to see where the mute pin is and make sure this is the one you connect the mute line on the loom to. It must be on here somewhere if ya do a search;)
Mute pin is pin 2 on the black iso block :D
Thanks guys, got it all connected and it works fine, have just installed a bluetooth hands free kit :thumbup:
